19
how do I set Clang 9 as the default C++ compiler on Ubuntu 19.10? I searched the internet, but nothing helped. Thank you for answer :)
  1. Install clang version 9 from the default Ubuntu repositories in Ubuntu 19.10 and later.
     sudo apt install clang-9
  2. /usr/bin/c++ is actually a symbolic link to:
     /etc/alternatives/c++
    which in turn is also a symbolic link to:
     /usr/bin/g++
    so on Ubuntu c++ is g++ and g++ is g++ explicitly.
    Set Clang 9 as the default C++ compiler using c++ so that build processes can still use g++ explicitly if they want to.
    sudo update-alternatives --install /usr/bin/c++ c++ /usr/bin/c++ 40
    sudo update-alternatives --install /usr/bin/c++ c++ /usr/bin/clang++-9 60
    sudo update-alternatives --config c++
After running sudo update-alternatives --config c++ a menu of c++ versions will appear and you will be asked to select the default c++ version as follows:
Press <enter> to keep the current choice[*], or type selection number:
Input a selection number from the menu and press Enter.
If you encounter a situation where a new kernel module or other system-critical component fails to compile with Clang, revert to GCC by switching back using the following update-alternatives command:
Select GCC (g++) from the list to ensure system stability.
Alternatively instead of setting Clang as the global default compiler, which could cause system-wide issues, you can specify Clang only for specific build processes.
clang-9 can also be installed in Ubuntu 18.04 if the bionic-proposed/universe repository ( deb http://XX.archive.ubuntu.com/ubuntu/ bionic-proposed universe ) is added to the Ubuntu 18.04 software sources. Replace XX in deb http://XX.archive.ubuntu.com/ubuntu/ bionic-proposed universe with your country code.
karel
  • 122,292
  • 133
  • 301
  • 332
Step 1: Install prerequisites
sudo apt-get install build-essential xz-utils curl
Step 2: Download the necessary binaries and extract them.
curl -SL http://releases.llvm.org/9.0.0/clang+llvm-9.0.0-x86_64-pc-linux-gnu.tar.xz | tar -xJC
Step 3: Renaming & moving the binaries.
mv clang+llvm-9.0.0-x86_64-pc-linux-gnu clang_9.0.0
sudo mv clang_9.0.0 /usr/local
Step 4: Tell our system where clang-9 is
export PATH=/usr/local/clang_9.0.0/bin:$PATH
export LD_LIBRARY_PATH=/usr/local/clang_9.0.0/lib:$LD_LIBRARY_PATH
Step 5: Test the installation
clang++ -stdlib=libc++ -std=c++2a -Wall example.cpp -o example
Note
Clang is not a version of GCC, so it cannot be set as an alternative for /usr/bin/gcc. Never try it, you may break some packages which require GCC-specific features not available in Clang.
