Plesk recommends to check df -h /
[root@s20284804 ~]# df -h /
Filesystem      Size  Used Avail Use% Mounted on
/dev/md1        4.0G  4.0G   22M 100% /
[root@s20284804 ~]# du -hsx /*
7.2M    /bin
55M /boot
4.0K    /cgroup
1.8M    /composer.phar
264K    /composer-setup.php
212K    /dev
4.0K    /domains.txt
32M /etc
88K /home
317M    /lib
23M /lib64
48K /lost+found
4.0K    /media
4.0K    /mnt
2.6G    /opt
du: cannot access `/proc/20669/task/20669/fd/4': No such file or directory
du: cannot access `/proc/20669/task/20669/fdinfo/4': No such file or directory
du: cannot access `/proc/20669/fd/4': No such file or directory
du: cannot access `/proc/20669/fdinfo/4': No such file or directory
0   /proc
8.0K    /README.md
871M    /root
14M /sbin
4.0K    /selinux
4.0K    /srv
0   /sys
16K /tmp
3.1G    /usr
41G /var
fdisk -l
Disk /dev/sdb: 1500.3 GB, 1500301910016 bytes
255 heads, 63 sectors/track, 182401 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0xc6b58f8a
   Device Boot      Start         End      Blocks   Id  System
/dev/sdb1               1         523     4194304   fd  Linux raid autodetect
Partition 1 does not end on cylinder boundary.
/dev/sdb2             523         784     2097152   82  Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/sdb3             784      182402  1458846104   fd  Linux raid autodetect
Partition 3 does not end on cylinder boundary.
Disk /dev/sda: 1500.3 GB, 1500301910016 bytes
Disk identifier: 0x49d63b46
/dev/sda1               1         523     4194304   fd  Linux raid autodetect
/dev/sda2             523         784     2097152   82  Linux swap / Solaris
/dev/sda3             784      182402  1458846104   fd  Linux raid autodetect
Disk /dev/md3: 1493.9 GB, 1493858320384 bytes
2 heads, 4 sectors/track, 364711504 cylinders
Units = cylinders of 8 * 512 = 4096 bytes
Disk identifier: 0x00000000
Disk /dev/md1: 4294 MB, 4294901760 bytes
2 heads, 4 sectors/track, 1048560 cylinders
Disk /dev/mapper/vg00-usr: 5368 MB, 5368709120 bytes
255 heads, 63 sectors/track, 652 cylinders
Disk /dev/mapper/vg00-var: 107.4 GB, 107374182400 bytes
255 heads, 63 sectors/track, 13054 cylinders
Disk /dev/mapper/vg00-home: 5368 MB, 5368709120 bytes
I don't know how i could free this up or increase it. Any advice?
