OP's main goal is to find out how applications launched via Desktop Entries aka .desktop files. There is no answer to this question, as it is implementation-dependent, and the specifications to which I've linked above provide no standard as to how the standard streams should be redirected if at all.
For recent Ubuntu versions it is possible to find where those sockets connect. The number you see in the brackets is the inode within kernel's sockfs virtual filesystem. Per proc(5) manual:
For file descriptors for pipes and sockets, the entries will
be symbolic links whose content is the file type with the
inode. A readlink(2) call on this file returns a string in
the format:
type:[inode]
For example, socket:[2248868] will be a socket and its inode
is 2248868. For sockets, that inode can be used to find more
information in one of the files under /proc/net/.
However, there's a catch to that. In case of pipes, the inode for read and write end is the same. For socket pair - it's not guaranteed. However, this is likely a Unix domain socket, and we could in theory find it's file handle. Per Stephane Chazelas's answer, I've used ss -x on Ubuntu 18.04 virtual machine with XFCE to find the endpoint of the socket with .desktop file in your question, but slightly modified code:
#!/usr/bin/env python3
import sys
import time
import datetime
while True:
sys.stdout.write('########### stdout %s\n' % datetime.datetime.now())
sys.stderr.write('+++++++++++ sdterr %s\n' % datetime.datetime.now())
time.sleep(1)
I did find the socket and it's end point apparently points to systemd socket:
adminx@bionicbeaver:~$ ls -l /proc/$(pgrep -f write-to-stdout )/fd/{0,1,2}
lr-x------ 1 adminx adminx 64 Dec 23 09:01 /proc/3773/fd/0 -> /dev/null
lrwx------ 1 adminx adminx 64 Dec 23 09:01 /proc/3773/fd/1 -> 'socket:[27437]'
lrwx------ 1 adminx adminx 64 Dec 23 09:01 /proc/3773/fd/2 -> 'socket:[26621]'
adminx@bionicbeaver:~$ ss -x | grep 27437
u_strESTAB 0 0 /run/systemd/journal/stdout 27438 * 27437
Rightfully, so with the modified code you will see in the output of journalctl -f that the code writes to the syslog
Dec 23 09:49:47 bionicbeaver /usr/lib/gdm3/gdm-x-session[1441]: ########### stdout 2019-12-23 09:49:45.726394
Dec 23 09:49:47 bionicbeaver /usr/lib/gdm3/gdm-x-session[1441]: ########### stdout 2019-12-23 09:49:46.734060
Dec 23 09:49:47 bionicbeaver /usr/lib/gdm3/gdm-x-session[1441]: ########### stdout 2019-12-23 09:49:47.734603
Dec 23 09:49:47 bionicbeaver /usr/lib/gdm3/gdm-x-session[1441]: +++++++++++ sdterr 2019-12-23 09:49:45.726459
Dec 23 09:49:47 bionicbeaver /usr/lib/gdm3/gdm-x-session[1441]: +++++++++++ sdterr 2019-12-23 09:49:46.734122
Dec 23 09:49:47 bionicbeaver /usr/lib/gdm3/gdm-x-session[1441]: +++++++++++ sdterr 2019-12-23 09:49:47.734787
Notice that the desktop manager gdm is responsible for passing those messages. If you perform a bit of filtering on /proc as described in a related question on pipes you will see that multiple processes connect to this same socket as clients, and gdm acts as sort of server for that.
However, this is not a consistent behavior. Per Gille's and Stephane's answers, finding the other end of socket pair is possible only with kernel above 3.3, and as I mentioned before it is up to desktop environment/window manager implementation to decide how to wire the standard streams. On a different Debian-based distro with Mutter the same code maps only to /dev/null
$ ls -l /proc/$(pgrep -f /var/tmp/write-to-stdout-sterr.py)/fd/{0,1,2}
lr-x------ 1 xie xie 64 Dec 23 16:38 /proc/16975/fd/0 -> /dev/null
l-wx------ 1 xie xie 64 Dec 23 16:38 /proc/16975/fd/1 -> /dev/null
l-wx------ 1 xie xie 64 Dec 23 16:38 /proc/16975/fd/2 -> /dev/null
In conclusion, do not expect this to be portable at all. Be explicit if you want to obtain the stdout or stderr of applications launched via the Desktop Entries.
