When redshift is running - screen dims a bit. This was noticeable while watching videos in VLC. Even if I "disable" redshift from its options the dimming remains. Only when I exit the program brightness returns to normal.
Day & night brightness values are also set as 1.0 in config so no issue there. There is no option related to dimming.
Not sure what is the problem or how can it be fixed.
Here is the redshift config:
; Global settings for redshift
[redshift]
; Set the day and night screen temperatures
temp-day=5500
temp-night=3800
; Enable/Disable a smooth transition between day and night
; 0 will cause a direct change from day to night screen temperature.
; 1 will gradually increase or decrease the screen temperature.
transition=1
; Set the screen brightness. Default is 1.0.
brightness=1.0
; It is also possible to use different settings for day and night
; since version 1.8.
brightness-day=1.0
brightness-night=1.0
; Set the screen gamma (for all colors, or each color channel
; individually)
; gamma=0.8
gamma=0.8:0.7:0.8
; This can also be set individually for day and night since
; version 1.10.
;gamma-day=0.8:0.7:0.8
;gamma-night=0.6
; Set the location-provider: 'geoclue', 'geoclue2', 'manual'
; type 'redshift -l list' to see possible values.
; The location provider settings are in a different section.
location-provider=manual
; Set the adjustment-method: 'randr', 'vidmode'
; type 'redshift -m list' to see all possible values.
; 'randr' is the preferred method, 'vidmode' is an older API.
; but works in some cases when 'randr' does not.
; The adjustment method settings are in a different section.
adjustment-method=randr
; Configuration of the location-provider:
; type 'redshift -l PROVIDER:help' to see the settings.
; ex: 'redshift -l manual:help'
; Keep in mind that longitudes west of Greenwich (e.g. the Americas)
; are negative numbers.
[manual]
lat=28.459497
lon=77.026634
; Configuration of the adjustment-method
; type 'redshift -m METHOD:help' to see the settings.
; ex: 'redshift -m randr:help'
; In this example, randr is configured to adjust screen 1.
; Note that the numbering starts from 0, so this is actually the
; second screen. If this option is not specified, Redshift will try
; to adjust _all_ screens.
[randr]
