How do I solve this login loop? Every time I have given the correct password, but my account is not opening. Every time it comes back to my login prompt. Crashes back to the login screen.
Eliah Kagan
  • 119,640
If you've been starting graphic applications from the terminal using sudo, that's what probably caused your problem. Always use sudo -H.
  • boot to the GRUB menu
  • choose Advanced Options
  • choose Recovery mode
  • choose Root access
  • at the # prompt, type:
     - sudo mount -o remount,rw / # remount the disk as rw
     - cd /home/your_username # change directory
     - ls -al .*thority* # list some files
You should see something like this...
-rw------- 1 your_username your_username 407910 Nov  2 08:56 .ICEauthority
-rw------- 1 your_username your_username     58 Jun 23  2017 .Xauthority
If it DOES NOT show -rw------- then...
  • sudo chmod 600 .*thority* # change file protection
If it DOES SHOW root root then...
  • sudo chown your_username:your_username .*thority* # change file ownership
  • reboot # reboot the computer
Reboot and see if you can log in.
heynnema
  • 73,649
