I have Lubuntu 18.0.4 on a thin client, 1.4ghz, 4gb ram. I would like to use it to play streamed internet radio stations like BBC radio 3 and also to play audio from a usb stick. Two problems: I am new to Lubuntu and the PC is quite limited in resources. But is quite fast on boot, so good for me. Any ideas please Thanks diode84
Asked
Active
Viewed 1,256 times
There is an audio player with a command-line interface called cmus which is very ight weight on resources which also allows streaming of internet radio and is also knows to open .m3u and .pls streams.
Also, cmus looks nice and offers several views, a file browser and many configuration settings. cmus is available from the standard Ubuntu repositories. ou can install using the command below
sudo apt install cmus
If you need help on how to use cmus, use the command
man cmus
Tejas Lotlikar
- 2,985
