The other day my system was upgraded to using Flash 11.2.202.228.
Since then I have had a slight "stutter" or "choppy" audio on playbacks. I would guess it is a buffer under run problem.
Anyone knows what has happened with the new flash-release?
well, it seems like there is a bug in Flash version 11.2.202.228. [launchpad]
Here I did find some clues.
So I downloaded the previous version (available from Abode as binaries), replaced by existing /usr/lib/flashplugin-installer/libflashplayer.sowith the one from the previous version.
And now sounds is working like a charm again.
Also, when the next flash upgrade comes along, the automatic upgrade should as normal.
Switch from Unity to Unity 2D ("Ubuntu 2D" on the login screen).
I did this and I can now play full-screen Flash video with no audio stutter.
Before I switched, Flash audio would stutter.
This is on 12.04 LTS 32-bit, on a Pentium T2600 with 3GB RAM, and version 11.2.202.235ubuntu0.12.04.1 of the flashplugin-installer package.
Eliah Kagan
  • 119,640
mrwmc
