On my Ubuntu desktop, the command fdisk -l shows /dev/loopX up to /dev/loop23. I'm using gnome-fallback on Ubuntu 18.04 LTS.
I'm wondering what possible effects these could have on performance and stabilty of the OS, and if they are just superfluous, how can I remove them?
root@pc5:~# fdisk -l
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop15: 3.7 MiB, 3821568 bytes, 7464 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
Disk /dev/loop16: 54.6 MiB, 57274368 bytes, 111864 sectors
Disk /dev/loop17: 140.7 MiB, 147501056 bytes, 288088 sectors
Disk /dev/loop18: 14.8 MiB, 15462400 bytes, 30200 sectors
Disk /dev/loop19: 42.8 MiB, 44879872 bytes, 87656 sectors
Disk /dev/loop20: 54.5 MiB, 57151488 bytes, 111624 sectors
Disk /dev/loop21: 4.2 MiB, 4403200 bytes, 8600 sectors
Disk /dev/loop22: 153.5 MiB, 160935936 bytes, 314328 sectors
Disk /dev/loop23: 140.7 MiB, 147501056 bytes, 288088 sectors
output of df:
Filesystem 1K-blocks Used Available Use% Mounted on
udev 8128184 0 8128184 0% /dev
tmpfs 1630464 3716 1626748 1% /run
/dev/sda2 229184876 63255488 154217748 30% /
tmpfs 8152300 142672 8009628 2% /dev/shm
tmpfs 5120 4 5116 1% /run/lock
tmpfs 8152300 0 8152300 0% /sys/fs/cgroup
/dev/loop2 160512 160512 0 100% /snap/gnome-3-28-1804/110
/dev/loop3 4352 4352 0 100% /snap/gnome-calculator/544
/dev/loop0 3840 3840 0 100% /snap/gnome-system-monitor/111
/dev/loop4 91264 91264 0 100% /snap/core/8039
/dev/loop1 1024 1024 0 100% /snap/gnome-logs/81
/dev/loop6 87936 87936 0 100% /snap/shotcut/55
/dev/loop5 406528 406528 0 100% /snap/redis-desktop-manager/332
/dev/loop8 91264 91264 0 100% /snap/core/8213
/dev/loop7 406656 406656 0 100% /snap/redis-desktop-manager/335
/dev/loop9 15104 15104 0 100% /snap/gnome-characters/367
/dev/loop11 157184 157184 0 100% /snap/chromium/949
/dev/loop12 87808 87808 0 100% /snap/shotcut/53
/dev/loop13 1024 1024 0 100% /snap/gnome-logs/73
/dev/loop14 45312 45312 0 100% /snap/gtk-common-themes/1353
/dev/loop16 55936 55936 0 100% /snap/core18/1279
/dev/loop15 3840 3840 0 100% /snap/gnome-system-monitor/107
/dev/loop10 159872 159872 0 100% /snap/gnome-3-28-1804/91
/dev/loop17 144128 144128 0 100% /snap/gnome-3-26-1604/97
/dev/sda1 523248 6232 517016 2% /boot/efi
/dev/loop18 15104 15104 0 100% /snap/gnome-characters/359
/dev/loop19 43904 43904 0 100% /snap/gtk-common-themes/1313
/dev/loop20 55936 55936 0 100% /snap/core18/1265
/dev/loop21 4352 4352 0 100% /snap/gnome-calculator/536
/dev/loop22 157184 157184 0 100% /snap/chromium/958
/dev/loop23 144128 144128 0 100% /snap/gnome-3-26-1604/98
/dev/sdb1 492127240 409174612 57930932 88% /home
tmpfs 1630460 16 1630444 1% /run/user/121
tmpfs 1630460 140 1630320 1% /run/user/1001
tmpfs 1630460 0 1630460 0% /run/user/0
