I have many files. File format is year(4-digit)month(2-digit)day(2-digit)
Sample filenames:
  • 20150101.txt
  • 20150102.txt
Content of sample filenames
00:00:13 -> 001528
I want to extract data as date from filename and then to insert it in the file
Desired output
2015-01-01T00:00:13 001528
or
2015-01-01 00:00:13 001528
I tried one of below code
for files in *txt; do
awk -F "->" 'BEGIN{OFS=""} {print FILENAME" ",$1, $2}' <$files > $files.edited
mv $files.edited $files
done
Please guide.
chess_freak
  • 121
If you have GNU awk (gawk) then you could use its built-in Time Functions to convert pieces of the file name and contents into an epoch time, and then convert it according to a chosen format.
Ex. given
$ cat 20150101.txt
00:00:13 -> 001528
Then
$ awk -F ' -> ' '
    split($1,a,/:/) {
      ds = sprintf("%04d %02d %02d %02d %02d %02d", substr(FILENAME,1,4), substr(FILENAME,5,2), substr(FILENAME,7,2), a[1], a[2], a[3]);
      $1 = strftime("%FT%T", mktime(ds))
  ' 20150101.txt
steeldriver
  • 142,475
This will give you the desired output using sed:
for files in *.txt; do
sed -e "s/^./$files&/;s/./&-/4;s/./&-/7;s/.txt/T/;s/ -> / /" "$files"
done
To actually insert each output into each file, you do not need to redirect as you did in your loop. You can simply use the -i option instead of -e.
  • the s (substitute) command uses the following syntax: s/regexp/replacement/flags
  • . matches any character and ^. matches the first character of a line
  • & back-references the whole matched portion of the pattern space
  • s/^./$files&/ says to substitute the first character with the filename before the first character
  • s/./&-/4 uses the number flag 4 to substitute the 4th character (the 4th match of .) with - after the 4th character
  • s/./&-/7 replace the 7th character with - after the 7th character (note that the 6th character becomes the 7th character after inserting - after the 4th character).
And of course,
  • s/.txt/T/ substitutes .txt with T and
  • s/ -> / / substitutes -> with a single blank space.
This is the output:
2015-01-02T00:00:13 001528
mchid
  • 44,904
  • 102
  • 162
