I need to fsck my drive, It boots saying i need to manually run fsck on ubuntu-studio-vg-root , fsck exited with status code 4, so I booted from livecd and went to run it, I have ubuntu studio 18.4 this is what i got
~ubuntu-studio@ubuntu-studio:~$ lsblk
NAME                          MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
ubuntu-studio@ubuntu-studio:~$ sudo fsck -f /dev/sda1
fsck from util-linux 2.31.1
e2fsck 1.44.1 (24-Mar-2018)
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/sda1: 308/124928 files (17.2% non-contiguous), 134315/498688 blocks
ubuntu-studio@ubuntu-studio:~$ sudo fsck /dev/sda1
/dev/sda1: clean, 308/124928 files, 134315/498688 blocks
ubuntu-studio@ubuntu-studio:~$ unmount /dev/sda5
Command 'unmount' not found, did you mean:
  command 'umount' from deb mount
Try: sudo apt install <deb name>
ubuntu-studio@ubuntu-studio:~$ sudo umount /dev/sda5
umount: /dev/sda5: not mounted.
ubuntu-studio@ubuntu-studio:~$ sudo umount /dev/sda1
umount: /dev/sda1: not mounted.
~ubuntu-studio@ubuntu-studio:~$ sudo fsck -f /dev/sda5
ubuntu-studio@ubuntu-studio:~$ sudo e2fsck /dev/sda1
ubuntu-studio@ubuntu-studio:~$ sudo e2fsck /dev/sda5
/dev/sda5 is in use.
e2fsck: Cannot continue, aborting.
ubuntu-studio@ubuntu-studio:~$ umount /dev/sda5
ubuntu-studio@ubuntu-studio:~$ umount /dev/sda2
umount: /dev/sda2: not mounted.
ubuntu-studio@ubuntu-studio:~$ sudo swapoff
swapoff: bad usage
Try 'swapoff --help' for more information.
ubuntu-studio@ubuntu-studio:~$ swapoff --help
Usage:
 swapoff [options] [<spec>]
Disable devices and files for paging and swapping.
Options:
 -a, --all              disable all swaps from /proc/swaps
 -v, --verbose          verbose mode
 -h, --help             display this help
 -V, --version          display version
The <spec> parameter:
 -L <label>             LABEL of device to be used
 -U <uuid>              UUID of device to be used
 LABEL=<label>          LABEL of device to be used
 UUID=<uuid>            UUID of device to be used
 <device>               name of device to be used
 <file>                 name of file to be used
For more details see swapoff(8).
I went though gparted and couldn't post a screenshot because this site is dumb but, there's a little gray down arrow next to /dev/sda2 but i doesn't say it's mounted it says dev/sda5 is in use even though it's unmounted,can someone please help me though this? i'm a noob and really need to save my files from this drive
