I am running Ubuntu 11.10 on a Compaq Presario CQ57 and I need to enable my wireless hardware switch to use it. I have a wireless key (F12) which shows a light when the switch is active (it is now red). How would I go about enabling in Ubuntu? I've tried pressing F12 normally and with Fn, none work.
Asked
Active
Viewed 3,747 times
This a common problem with that model.
Here is solution
http://www.techytalk.info/ubuntu-ppas/ralink-wireless/
Linked question :
This might help: https://bbs.archlinux.org/viewtopic.php?pid=1413379#p1413379
Try to unload the wmi module.
For example, this worked for me on HP Mini 100e:
sudo rmmod hp-wmi
sudo rmmod wmi
after which I could immediately connect to wi-fi.
(Find your corresponding module using lsmod)
If this works for you, you might want to blacklist the wmi module from /etc/modprobe.d/ -- see link for instructions.
anonymous2
- 4,325
M 0
- 1
