im running out of space and i tried to resize the partition using g-parted but i got an error:
Checking for bad sectors ...
Bad cluster: 0x2904636 - 0x2904636 (1)
Bad cluster: 0x290526d - 0x290526e (2)
Bad cluster: 0x29052fd - 0x2905300 (4)
Bad cluster: 0x2905392 - 0x2905392 (1)
Bad cluster: 0x2905425 - 0x2905428 (4)
Bad cluster: 0x290555d - 0x2905560 (4)
Bad cluster: 0x29055f1 - 0x29055f8 (8)
Bad cluster: 0x2905681 - 0x2905688 (8)
Bad cluster: 0x29057ac - 0x29057ac (1)
Bad cluster: 0x29887dd - 0x29887dd (1)
Bad cluster: 0x299a086 - 0x299a086 (1)
Bad cluster: 0x348ec05 - 0x348ec05 (1)
Bad cluster: 0x353dabb - 0x353dabb (1)
Bad cluster: 0x353dba4 - 0x353dba4 (1)
Bad cluster: 0x354a162 - 0x354a162 (1)
Bad cluster: 0x354a1ce - 0x354a1ce (1)
ERROR: This software has detected that the disk has at least 40 bad sectors.
* WARNING: The disk has bad sector. This means physical damage on the disk *
* surface caused by deterioration, manufacturing faults or other reason. *
* The reliability of the disk may stay stable or degrade fast. We suggest *
* making a full backup urgently by running 'ntfsclone --rescue ...' then *
* run 'chkdsk /f /r' on Windows and rebooot it TWICE! Then you can resize *
* NTFS safely by additionally using the --bad-sectors option of ntfsresize.*
I opened the "disk utility" and clicked on "Smart DATA" button I got this image:
Smart data on disk utility
jrg
  • 61,707
speedox
  • 1,054
STOP!
Backup everything important. See Comparison of backup tools
This is a:
Potential Hard Drive failure.
Ringtail
  • 16,285
It looks like you've got a bad hard drive. Might be time for a new one
Finn
  • 334
