After a kernel update of Kubuntu 19.10 (i.e., via normal updates), wifi has stopped working, and the driver is not loaded anymore. I have tried to run sudo modprobe -v iwlwifi unsuccessfully with this result:
insmod /lib/modules/5.3.0-24-generic/updates/dkms/compat.ko
modprobe: ERROR: could not insert 'iwlwifi': Operation not permitted
I believe this may be due to SecureBoot and the fact that I need to sign the iwlwifi module.
I found this example for signing kernel modules for SecureBoot and tried it out for the VirtualBox example shown there. This worked for VirtualBox. (It had bothered me for a while that VirtualBox didn't work anyway.) Then I tried the same thing with iwlwifi as follows:
sudo /usr/src/linux-headers-$(uname -r)/scripts/sign-file sha256 ./MOK.priv ./MOK.der $(modinfo -n iwlwifi)
But this time, there was no effect. The error message above ("Operation not permitted") persisted.
I tried disabling SecureBoot in the BIOS, but then Kubuntu wouldn't start up anymore. I could enter the password, but then the desktop was grayed out and the system froze.
So I switched Secure Boot back on. When listing yesterday's updates, grep " upgrade " /var/log/dpkg.log yielded, among other things:
2019-12-07 09:47:31 upgrade backport-iwlwifi-dkms:all 7906-0ubuntu1 7906-0ubuntu2~19.10.1
In my attempt to fix things, I deinstalled and subsequently re-installed backport-iwlwifi-dkms. While re-installing, I was guided through the process for signing the module for Secure Boot. This looked promising initially, but after a reboot, the system would not start anymore. So now I am getting a freezing system with a grayed out desktop with or without Secure Boot activated. I can still boot into the previous kernel version from the boot menu, though.
Eoan backports are enabled in the sources list.
While in the previous kernel version, dkms status yields the following output:
backport-iwlwifi, 7906, 5.3.0-24-generic, x86_64: installed (WARNING! Diff between built and installed module!)
virtualbox, 6.0.14, 5.3.0-23-generic, x86_64: installed
virtualbox, 6.0.14, 5.3.0-24-generic, x86_64: installed (WARNING! Diff between built and installed module!)
And ls -al /lib/modules/*/updates/dkms yields the following output:
/lib/modules/5.3.0-23-generic/updates/dkms:
total 636
drwxr-xr-x 2 root root 4096 Dec 8 15:33 .
drwxr-xr-x 3 root root 4096 Nov 15 09:06 ..
-rw-r--r-- 1 root root 547635 Nov 15 09:06 vboxdrv.ko
-rw-r--r-- 1 root root 15523 Nov 15 09:06 vboxnetadp.ko
-rw-r--r-- 1 root root 38803 Nov 15 09:06 vboxnetflt.ko
-rw-r--r-- 1 root root 36331 Nov 15 09:06 vboxpci.ko
/lib/modules/5.3.0-24-generic/updates/dkms:
total 4408
drwxr-xr-x 2 root root 4096 Dec 8 15:37 .
drwxr-xr-x 3 root root 4096 Dec 7 09:49 ..
-rw-r--r-- 1 root root 1124323 Dec 8 15:37 cfg80211.ko
-rw-r--r-- 1 root root 7227 Dec 8 15:37 compat.ko
-rw-r--r-- 1 root root 684483 Dec 8 15:37 iwlmvm.ko
-rw-r--r-- 1 root root 676194 Dec 8 12:29 iwlwifi.ko
-rw-r--r-- 1 root root 82699 Dec 8 15:37 iwlxvt.ko
-rw-r--r-- 1 root root 1272979 Dec 8 15:37 mac80211.ko
-rw-r--r-- 1 root root 548088 Dec 8 12:06 vboxdrv.ko
-rw-r--r-- 1 root root 15523 Dec 7 09:49 vboxnetadp.ko
-rw-r--r-- 1 root root 38803 Dec 7 09:49 vboxnetflt.ko
-rw-r--r-- 1 root root 36331 Dec 7 09:49 vboxpci.ko
Edit: @heynnema asked me to post the output of several commands as part of his answer below:
Step 3:
ls -al /etc/modprobe.d:
total 60
drwxr-xr-x 2 root root 4096 Dec 5 13:52 .
drwxr-xr-x 143 root root 12288 Dec 7 09:49 ..
-rw-r--r-- 1 root root 2507 Jul 31 2015 alsa-base.conf
-rw-r--r-- 1 root root 154 Aug 1 02:54 amd64-microcode-blacklist.conf
-rw-r--r-- 1 root root 325 Apr 30 2019 blacklist-ath_pci.conf
-rw-r--r-- 1 root root 1518 Apr 30 2019 blacklist.conf
-rw-r--r-- 1 root root 210 Apr 30 2019 blacklist-firewire.conf
-rw-r--r-- 1 root root 677 Apr 30 2019 blacklist-framebuffer.conf
-rw-r--r-- 1 root root 156 Jul 31 2015 blacklist-modem.conf
lrwxrwxrwx 1 root root 41 Oct 31 12:22 blacklist-oss.conf -> /lib/linux-sound-base/noOSS.modprobe.conf
-rw-r--r-- 1 root root 583 Apr 30 2019 blacklist-rare-network.conf
-rw-r--r-- 1 root root 127 Oct 3 10:38 dkms.conf
-rw-r--r-- 1 root root 154 Sep 30 19:37 intel-microcode-blacklist.conf
-rw-r--r-- 1 root root 347 Apr 30 2019 iwlwifi.conf
more /etc/modprobe.d/iwlwifi.conf:
# /etc/modprobe.d/iwlwifi.conf
# iwlwifi will dyamically load either iwldvm or iwlmvm depending on the
# microcode file installed on the system. When removing iwlwifi, first
# remove the iwl?vm module and then iwlwifi.
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
dkms status shows nothing.
ls -al /lib/modules/*/updates/dkms:
total 8
drwxr-xr-x 2 root root 4096 Dec 8 17:25 .
sudo lshw -C network:
*-network:0 UNCLAIMED
description: Network controller
product: Cannon Point-LP CNVi [Wireless-AC]
vendor: Intel Corporation
physical id: 14.3
bus info: pci@0000:00:14.3
version: 30
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix cap_list
configuration: latency=0
resources: memory:c9738000-c973bfff
*-network:1
description: Ethernet interface
product: Ethernet Connection (6) I219-LM
physical id: 1f.6
bus info: pci@0000:00:1f.6
logical name: enp0s31f6
version: 30
serial: 98:fa:9b:d4:56:64
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k duplex=full firmware=0.4-3 ip=192.168.1.213 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:147 memory:c9700000-c971ffff
Step 4:
Un- and re-installed virtualbox (as virtualbox-6.0 did not exist). The remaining two commands in Step 4 do not return anything.
Step 5:
ls -al /lib/modules/5.3.0-24-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko:
-rw-r--r-- 1 root root 640985 Nov 13 22:41 /lib/modules/5.3.0-24-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
modinfo iwlwifi:
filename: /lib/modules/5.3.0-24-generic/updates/dkms/iwlwifi.ko
modinfo: ERROR: could not get modinfo from 'iwlwifi': No such file or directory
dpkg -l *virtualbox*:
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii virtualbox 6.0.14-dfsg-1 amd64 x86 virtualization solution - base binaries
un virtualbox-2.0 <none> <none> (no description available)
un virtualbox-2.1 <none> <none> (no description available)
un virtualbox-2.2 <none> <none> (no description available)
un virtualbox-3.0 <none> <none> (no description available)
un virtualbox-3.1 <none> <none> (no description available)
un virtualbox-3.2 <none> <none> (no description available)
un virtualbox-4.0 <none> <none> (no description available)
un virtualbox-4.1 <none> <none> (no description available)
un virtualbox-4.2 <none> <none> (no description available)
un virtualbox-4.3 <none> <none> (no description available)
un virtualbox-5.0 <none> <none> (no description available)
un virtualbox-5.1 <none> <none> (no description available)
un virtualbox-5.2 <none> <none> (no description available)
un virtualbox-6.0 <none> <none> (no description available)
ii virtualbox-dkms 6.0.14-dfsg-1 all x86 virtualization solution - kernel module sources for dkms
un virtualbox-guest-additions-iso <none> <none> (no description available)
un virtualbox-guest-dkms <none> <none> (no description available)
un virtualbox-guest-modules <none> <none> (no description available)
un virtualbox-modules <none> <none> (no description available)
ii virtualbox-qt 6.0.14-dfsg-1 amd64 x86 virtualization solution - Qt based user interface
un virtualbox-source <none> <none> (no description available)
cat /etc/network/interfaces:
cat: /etc/network/interfaces: No such file or directory
cat /etc/netplan/*.yaml:
# Let NetworkManager manage all devices on this system
network:
version: 2
renderer: NetworkManager
Step 6:
VirtualBox cannot be opened. Error message:
Kernel driver not installed (rc=-1908)
The VirtualBox Linux kernel driver is either not loaded or not set up correctly. Please reinstall virtualbox-dkms package and load the kernel module by executing
'modprobe vboxdrv'
as root.
If your system has EFI Secure Boot enabled you may also need to sign the kernel modules (vboxdrv, vboxnetflt, vboxnetadp, vboxpci) before you can load them. Please see your Linux system's documentation for more information.
where: suplibOsInit what: 3 VERR_VM_DRIVER_NOT_INSTALLED (-1908) - The support driver is not installed. On linux, open returned ENOENT.
Enabled the backports, wanted to re-install backport-iwlwifi-dkms, but it was already there. I clicked on re-install. After that, dkms status returned backport-iwlwifi, 7906, 5.3.0-24-generic, x86_64: installed.
Output of sudo lshw -C network:
*-network:0
physical id: 14.3
version: 30
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list
configuration: driver=iwlwifi latency=0
resources: irq:16 memory:c9738000-c973bfff
*-network:1
physical id: 1f.6
version: 30
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
total 3776
drwxr-xr-x 2 root root 4096 Dec 8 18:48 .
-rw-r--r-- 1 root root 1124323 Dec 8 18:48 cfg80211.ko
-rw-r--r-- 1 root root 7227 Dec 8 18:48 compat.ko
-rw-r--r-- 1 root root 684483 Dec 8 18:48 iwlmvm.ko
-rw-r--r-- 1 root root 674835 Dec 8 18:48 iwlwifi.ko
-rw-r--r-- 1 root root 82699 Dec 8 18:48 iwlxvt.ko
-rw-r--r-- 1 root root 1272979 Dec 8 18:48 mac80211.ko
