Before completely reinstalling I'd like to try to get some help here;
I've updated Ubuntu yesterday. After the next restart my system booted into the GRUB command line (as described in many other threads, e.g. https://unix.stackexchange.com/questions/474510/unwanted-grub-command-prompt-while-booting).
After following pretty much every guide I was able to execute the boot command after
linux /boot/<path-to-image>
initrd /<path-to-image>
boot
But this doesn't solve my problem and instead brings up the BusyBox (like Boot drops to a (initramfs) prompts/busybox).
From there I'm not able to do anything; fdisk does nothing, exit or reboot causes kernel panic.
I've also tried to boot from USB stick and ran fdisk - but that didn't help at all.
Is there anything left I can do?
(I'm running Windows AND Ubuntu in the same system, on two different SSDs)
nehalist
  • 121
I didn't know about the boot-repair utility (http://ubuntuhandbook.org/index.php/2016/11/install-boot-repair-ppa-fix-boot-problems/).
Booted via USB, installed boot-repair which was capable of fixing my boot. Thanks, boot-repair utility!
nehalist
  • 121
