For building the minitube ( https://github.com/flaviotordini/minitube ) I need to have a version later than the one offered by the repositories. The reason I am asking is because the developer supports Later Ubuntu versions than the LTS one (18.04)
So I need to build it by myself. Also, I have installed previous versions of minitube by manually compiling it.
Based upon this answer I used the ppa:beineri/opt-qt-5.12.0-bionic
but misses the qttools512-dev-tools package hence the build fails on:
/opt/qt512/bin/lrelease locale/ar.ts -qm build/target/locale/ar.qm
make: /opt/qt512/bin/lrelease: Command not found
Makefile:904: recipe for target 'build/target/locale/ar.qm' failed
make: *** [build/target/locale/ar.qm] Error 127
SO how I can install a later version of qt in order to build the minitube. Also keep in mind that the solution should not require the whole QTCreator because I find it kinda bloated in norder to use it just for a built.
