[edit] I just realized that Ubuntu didn't installed on SSD - I just assumed it did.
I have installed Ubuntu 19.10 on HDD of Dell Inspirion following this instruction https://askubuntu.com/a/1127541/1022455
Windows on SSD startups in ~16s and Ubuntu ~55s.
$ systemd-analyze time
Startup finished in 3.204s (kernel) + 1min 18.943s (userspace) = 1min 22.147s
graphical.target reached after 1min 18.837s in userspace
$ systemd-analyze blame
52.979s plymouth-quit-wait.service
14.469s dev-sda3.device
10.106s NetworkManager-wait-online.service
9.651s networkd-dispatcher.service
9.650s systemd-journal-flush.service
9.455s snapd.service
8.486s ModemManager.service
7.680s udisks2.service
7.272s accounts-daemon.service
6.186s dev-loop0.device
5.571s grub-common.service
5.399s secureboot-db.service
5.328s apport.service
4.636s NetworkManager.service
4.561s switcheroo-control.service
4.559s rsyslog.service
4.555s grub-initrd-fallback.service
4.554s thermald.service
4.551s bluetooth.service
4.505s plymouth-read-write.service
4.496s dev-loop4.device
4.342s avahi-daemon.service
3.942s systemd-logind.service
3.940s gpu-manager.service
3.935s pppd-dns.service
3.640s apparmor.service
3.623s wpa_supplicant.service
3.601s dev-loop2.device
3.367s dev-loop5.device
3.101s e2scrub_reap.service
3.055s dev-loop3.device
3.031s dev-loop1.device
3.002s dev-loop6.device
2.816s systemd-resolved.service
2.552s systemd-udevd.service
2.152s plymouth-start.service
1.692s gdm.service
1.624s packagekit.service
1.515s polkit.service
1.011s systemd-backlight@leds:dell::kbd_backlight.service
744ms systemd-modules-load.service
674ms systemd-rfkill.service
642ms systemd-backlight@backlight:intel_backlight.service
639ms systemd-timesyncd.service
619ms upower.service
615ms systemd-sysusers.service
586ms systemd-sysctl.service
540ms keyboard-setup.service
498ms snap-core-7917.mount
441ms systemd-journald.service
439ms systemd-fsck@dev-disk-by\x2duuid-3637\x2dAEF4.service
434ms systemd-udev-trigger.service
349ms snap-core18-1223.mount
332ms snap-gnome\x2d3\x2d28\x2d1804-71.mount
319ms snapd.seeded.service
307ms systemd-random-seed.service
303ms snap-gtk\x2dcommon\x2dthemes-1353.mount
300ms snap-gnome\x2dlogs-81.mount
278ms snap-gnome\x2dcharacters-317.mount
264ms systemd-tmpfiles-setup-dev.service
260ms ufw.service
232ms snap-gnome\x2dcalculator-501.mount
232ms systemd-tmpfiles-setup.service
229ms systemd-user-sessions.service
211ms systemd-remount-fs.service
203ms colord.service
180ms user@1000.service
159ms dev-mqueue.mount
122ms systemd-update-utmp.service
118ms kerneloops.service
104ms openvpn.service
100ms setvtrgb.service
87ms rtkit-daemon.service
81ms sys-kernel-debug.mount
81ms kmod-static-nodes.service
79ms dev-hugepages.mount
63ms boot-efi.mount
23ms snapd.socket
21ms systemd-update-utmp-runlevel.service
17ms console-setup.service
9ms user-runtime-dir@1000.service
2ms sys-fs-fuse-connections.mount
1ms sys-kernel-config.mount
$ systemd-analyze critical-chain
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @51.809s
└─multi-user.target @51.809s
└─kerneloops.service @38.653s +213ms
└─network-online.target @38.622s
└─NetworkManager-wait-online.service @27.210s +11.411s
└─NetworkManager.service @21.074s +6.118s
└─dbus.service @21.071s
└─basic.target @20.653s
└─sockets.target @20.653s
└─snapd.socket @20.652s +755us
└─sysinit.target @20.605s
└─cryptsetup.target @20.590s
└─systemd-ask-password-wall.path @2.550s
└─-.mount @2.548s
└─system.slice @2.548s
└─-.slice @2.548s
I went thru suggeste links and below are results
thanks for your help. I think the first link is not same issue, there is no apt-daily in my startup process.
turned off swap (I have 16GB of RAM, and default swap was 1GB)
Startup finished in 3.352s (kernel) + 51.883s (userspace) = 55.236s
graphical.target reached after 51.809s in userspace
sudo apt autoremove --purge snapd
Startup finished in 3.325s (kernel) + 45.791s (userspace) = 49.117s
graphical.target reached after 45.708s in userspace
edit journal by: https://askubuntu.com/a/1094543/1022455
Startup finished in 3.536s (kernel) + 41.438s (userspace) = 44.974s
graphical.target reached after 41.373s in userspace
Don't know if there is anything more worth dooing? What is the expected boot time of Ubuntu? It still turns on slower than ubuntu
[edit]
Updated critical chain
graphical.target @28.709s
└─multi-user.target @28.709s
└─kerneloops.service @28.554s +153ms
└─network-online.target @28.552s
└─NetworkManager-wait-online.service @19.311s +9.240s
└─NetworkManager.service @14.001s +5.306s
└─dbus.service @13.994s
└─basic.target @13.911s
└─paths.target @13.911s
└─acpid.path @13.911s
└─sysinit.target @13.578s
└─systemd-timesyncd.service @12.952s +626ms
└─systemd-tmpfiles-setup.service @11.804s +1.108s
└─systemd-journal-flush.service @3.142s +8.661s
└─systemd-journald.service @2.808s +332ms
└─syslog.socket @2.806s
└─system.slice @2.572s
└─-.slice @2.572s
