Traceback (most recent call last):
File "/usr/lib/cnf-update-db", line 8, in <module>
from CommandNotFound.db.creator import DbCreator
File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py",
line 11, in <module>
import apt_pkg
ModuleNotFoundError: No module named 'apt_pkg'
Error in sys.excepthook:
File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 63,
in apport_excepthook
from apport.fileutils import likely_packaged, get_recent_crashes
File "/usr/lib/python3/dist-packages/apport/__init__.py", line 5, in
<module>
from apport.report import Report
File "/usr/lib/python3/dist-packages/apport/report.py", line 30, in
<module>
import apport.fileutils
File "/usr/lib/python3/dist-packages/apport/fileutils.py", line 23, in
<module>
from apport.packaging_impl import impl as packaging
File "/usr/lib/python3/dist-packages/apport/packaging_impl.py", line 24, in <module>
import apt
File "/usr/lib/python3/dist-packages/apt/__init__.py", line 23, in <module>
import apt_pkg
Original exception was:
import apt_pkg
Reading package lists... Done
E: Problem executing scripts APT::Update::Post-Invoke-Success 'if
/usr/bin/test -w /var/lib/command-not-found/ -a -e /usr/lib/cnf-update-
db; then /usr/lib/cnf-update-db > /dev/null; fi'
E: Sub-process returned an error code
Asked
Active
Viewed 146 times
Your question is about how to upgrade Python3 without breaking apt as mentioned in comments by @user535733. You can just install several versions of python in parallel on your machine.
You can easily fond tutorials for that: https://www.freecodecamp.org/news/manage-multiple-python-versions-and-virtual-environments-venv-pyenv-pyvenv-a29fb00c296f/
hackela
- 188
