My laptop currently has only a 256GB SSD which has Windows 10 pre-installed on it. I don't need Ubuntu to be installed on this SSD, so I will remove this drive. I am planning to remove the Windows 10 SSD and run only Ubuntu on this laptop on 2 1TB SSDs.
I need Ubuntu to be installed on a 1TB NVMe SSD and another 1TB 2.5" internal SSD which I will put in this laptop as a replacement for the old 256GB SSD. Then I would be able to use LVM to manage these two storage devices in order to make the most efficient use of both drives. I'm going to use these two drives for some heavy machine learning and deep learning projects. I'm not planning to create any virtual machine guest OSs on this laptop, only an Ubuntu 18.04 single boot. How to partition the 2 SSDs on my laptop for an Ubuntu 18.04 single boot?
As far as I know it is required that we need root (/), swap home (/home) partitions. I need this 2TB of disk space (1 + 1) to be used efficiently for only this three partitions without mounting any one of these drives. I have did some research where with 1TB -
swap(SWAP) - 32GB
root(/) - rest of capacity after swap allocated
home(/home) - whole 1TB allocated
In my opinion does root need that much storage capacity? Is there any way to reduce this and add that storage capacity to home? Because I need home storage capacity to be more as I do heavy work?
