I bought a computer a couple of months ago wasn't able to make it work so tried again, here is the spec:
When trying to install I got these error messages:
  • nouveau : unknown chipset
  • PCIE bus error: severity=corrected, type physical layer
After installing I was able to reach the login screen, when I move my mouse over my user name to log in, mouse movements are choppy. and after i enter password (also choppy typing) I return to the login screen.
I've spent a lot of hours on this and no success.
Edit:
  • tried to install for desktop 18.04.03 and 19.10
  • I didn't enable HWE, just downloaded from the official website created ISO and tried to install
    • How do I enable HWE?
How do I make it work?
K7AAY
  • 17,705
The same happened to me, that's a problem related to the NVIDIA Kernel Module failing with proprietary drivers. To solve it, do the following steps:
  • At the login screen, press ctrl+alt+f2 and login with your name and password
  • Type sudo nano /etc/default/grub (you can change nano to the text editor of your preference, but nano is Ubuntu's default text editor) to edit /etc/default/grub
  • Change the line GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" to GRUB_CMDLINE_LINUX_DEFAULT="nomodset"
  • Update this grub edit with update grub
  • Install lightdm using sudo apt-get install lightdm
  • Reboot (you can shutdown throught the terminal with shutdown now)
