In order to speed up typing of a long command, we can make an alias of a command, e.g.
alias remcopy='scp user@123.45.67.89:/home/file.txt /home/user/'
And we type user this exact command will be run.
However, is it possible only to load the command and then modify it according to the current need, e.g.
scp user@123.45.67.89:/home/file.txt /home/user/addeddir/
cerebrou
  • 476
There are two ways you can start various modifications of the command.
  • an alias can have a parameter, for example
    alias remcopy='scp user@123.45.67.89:/home/user/file.txt'
    remcopy targetname
    where targetname is selected a run time.
  • a function is more flexible than an alias. It can be a single line or big like a whole shellscript file.
    function remcopy () { scp user@123.45.67.89:/home/user/file.txt /home/user/"$1" ; }
    remcopy
    remcopy addeddir
    which can be used without a parameter and with a parameter (in order to change the name of the target file.
    You can store a small function in ~/.bashrc like you store aliases.
sudodus
  • 47,684
You can use variables to accomplish this.
For example:
alias something='nano ${1}'
something test.txt
Will open test.txt in nano for writing
stratus
  • 651
