I want to give access to serial port /dev/ttyACM0. How to execute the "sudo chmod 777 /dev/ttyACM0" command from shell script ?
N0rbert
  • 103,263
Giving 777 permission to a file is not at all recommended. Since you want to give access to the Serial port, you have to add the user to the dialout group
sudo usermod -a -G dialout <username>
Now, no permission will be asked while accessing the serial port.
Note that this solution will also work for uploading code to Arudino boards in Arduino IDE or Serial Monitor in Ubuntu.
