I need to install wifi drivers on my laptop, the drivers I have use 'Make' during the install process.
How can I download 'Make' without installing and save to usb (obviously using a pc with internet connection)?
Kaigo
  • 585
You can ask apt-get for the packages that will be installed like this:
sudo apt-get --print-uris install make | cut -d"'" -f2 | grep http > /tmp/packages.list
Then you copy that file and, on another computer you do:
wget -i packages.list
Then you move the .deb packages you just downloaded to /var/cache/apt/archives on the unconnected computer.
And run:
sudo apt-get install make
That should do it.
First, download the packages listed below
http://archive.ubuntu.com/ubuntu/pool/main/m/make-dfsg/make_4.1-9.1ubuntu1_amd64.deb
http://archive.ubuntu.com/ubuntu/pool/main/g/glibc/libc6_2.27-3ubuntu1_amd64.deb
http://archive.ubuntu.com/ubuntu/pool/main/g/gcc-8/libgcc1_8-20180414-1ubuntu2_amd64.deb
http://archive.ubuntu.com/ubuntu/pool/main/g/gcc-8/gcc-8-base_8-20180414-1ubuntu2_amd64.deb
make requires libc6, libc6 requires libgcc1, libgcc1 requires gcc-8-base.
Copy these packages to a folder and transfer it to the pc on which they are to be installed.
Now, open a terminal into that folder and type the command
sudo dpkg -i *
