17
I am aware that you can right-click on an application and choose "Add to Favorites". I am trying to add it to the favorites section without using the GUI at all. Everything needs to be done in the terminal or a script.
Anyone have any ideas?
This is not a duplicate of this question. That is for SETTING the favorites, not ADDING to the favorites. When you right click on an application and choose "Add to Favorites", that must run a script somewhere that takes an input of the application name. What I'm asking is, where is that script or how can I replicate it?
pomsky
  • 70,557
Unfortunately, as an end-user you can only "read" and "write" (also reset) the array that dictates the list of favourite apps by using dconf/gsettings. For example, as mentioned here, you can get the value by running
gsettings get org.gnome.shell favorite-apps
and write a new value by a suitable gsettings set command. There is no straightforward way to append to the array, you can only overwrite.
But you can combine these two and have a custom command. You need to know the name of the .desktop launcher associated to the application you want to add to the favourites first. Let's say it is appname.desktop. Then you can run the following to add the application associated to appname.desktop to the favourites:
gsettings set org.gnome.shell favorite-apps "$(gsettings get org.gnome.shell favorite-apps | sed s/.$//), 'appname.desktop']"
pomsky
  • 70,557
The path for dconf is: /org/gnome/shell/favorite-apps. For example
dconf read /org/gnome/shell/favorite-apps
Which for me produces
['org.gnome.Nautilus.desktop', 'firefox.desktop', 'vivaldi-stable.desktop', 'steam.desktop']
So in theory you could use dconf write to adjust these values
Pablo Bianchi
  • 17,371
stratus
  • 651
