-1
I have upgraded my Ubuntu 18.04 to 19.04 and then 19.10. Since that time I see nothing on both screens except a homogeneous black surface. On the second monitor is blinking the green LED - normally showing with continuous light the supply voltage is on - probably showing the lack of video signal.
Would be possible somehow to repair this ?
If it is impossible have I to delete the whole partition (loosing the earlier settings of ubuntu 18.04) and reinstall the old good ubuntu 18.04? Thanks in advance for your kind support.
Mark Kirby
  • 18,949
  • 19
  • 79
  • 116
kacor
After starting the computer you can select between the start modes. In the GRUB menu select Advanced options for Ubuntu 19.10. In the next screen select kernel version 4.15.0.70 instead the 5.x series kernel. Use the ↑ and ↓ keys to select which entry is highlighted. Press Enter to boot the selected kernel.
karel
  • 122,292
  • 133
  • 301
  • 332
