25
This doesn't work:
$ ls "~/.wine/drive_c/tools/Family Tree v2.0"
ls: cannot access '~/.wine/drive_c/tools/Family Tree v2.0': No such file or directory
But this does:
$ ls "/home/daniel/.wine/drive_c/tools/Family Tree v2.0"
Dossiers                           Dossiers_orig   Infos.opt      Racines.exe  'Register OCX.bat'   racines.CNT
Dossiers-2019.11.03-11.46.tar.gz   Html            REGSVR32.exe   Racines.hlp   Uninst.isu          readme.txt
Given that ~ is supposed to be the same as /home/daniel, what's going on here?
damadam
  • 2,873
Gigi
  • 691
  • 19
Quoting, even with double quotes, suppresses tilde expansion.
~ can be used as a path to your home directory in contexts where tilde expansion is performed. ~ is not like . or ... There aren't actually any entries in your filesystem called ~ that serve as alternate names for your home directory.
When ~ appears by itself or as the first component of a path, your shell expands it into an absolute path to your home directory. But this does not happen when ~ is quoted. Double quotes provide a weaker form of quoting than single quotes, which is important to some other kinds of expansion, such as parameter expansion (which expands $HOME). But even double quotes suppress tilde expansion.
Thus ~ was not expanded in this command, where it is quoted:
Fortunately, it is permitted to write an argument some of whose parts are quoted and some of whose parts are not. So you can put ~/ before the quotes, and still quote the rest:
ls ~/".wine/drive_c/tools/Family Tree v2.0"
Or, since parameter expansion is performed even in double quotes--but not in single quotes--you can use:
ls "$HOME/.wine/drive_c/tools/Family Tree v2.0"
(Technically that is different, in that even when the HOME environment variable is unset, some shells still try to figure out what your home directory is and expand ~ to it--and bash is one such shell. But it's both rare and inadvisable to have HOME unset.)
Further reading:
Eliah Kagan
  • 119,640
