I would like to explore concepts and other new features in C++20, provided by g++ 10. However, I cannot seem to find any resources that allows me to apt-get a g++ 10 online?
What is the easiest way for me to get g++10 installed?
gcc-10 is now available in the Ubuntu tool chains.
Add the PPA and install gcc-10:
sudo add-apt-repository ppa:ubuntu-toolchain-r/test
sudo apt-get update
sudo apt install gcc-10
For g++-10:
sudo apt install g++-10
At the end you need to update the alternatives for compilers (reference):
#Remove the previous alternatives
sudo update-alternatives --remove-all gcc
sudo update-alternatives --remove-all g++
#Define the compiler
sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-10 30
sudo update-alternatives --install /usr/bin/g++ g++ /usr/bin/g++-10 30
sudo update-alternatives --install /usr/bin/cc cc /usr/bin/gcc 30
sudo update-alternatives --set cc /usr/bin/gcc
sudo update-alternatives --install /usr/bin/c++ c++ /usr/bin/g++ 30
sudo update-alternatives --set c++ /usr/bin/g++
#Confirm and update (You can use the default setting)
sudo update-alternatives --config gcc
sudo update-alternatives --config g++
