To install single-boot Ubuntu on an Early 2011 17" MacBook Pro I went through the following steps:
  • Prepare a USB flash using Etcher and the Ubuntu 18.04 ISO file.
  • Press Option. Select to boot from USB. Press e, add nomodeset after quiet splash.
  • This enables me to install Ubuntu, apparently successfully, but after installation and at the first reboot, the machine hangs on the purple screen.
Should nomodeset be added to the start scripts when booting the OS from disk, not just the OS on USB? If yes, what needs to be modified?
My other experiment so far was slightly more successful. Installing the Arch Linux ISO, still using Etcher, on a USB makes it possible to install Arch Linux on the Macbook and boot properly. But the machine boots into a full-screen terminal. No KDE, etc. (but of course this is the wrong forum for that.)
Calaf
  • 123
The boot option nomodeset is used to help the graphics work with some graphics chips/cards, where the standard linux drivers do not work well.
This is independent of the boot media (so if it is needed when booting from USB it will also be needed when booting from DVD or HDD or SSD).
In an installed system you should edit the file /etc/default/grub
See this link: Configuring GRUB 2 - /etc/default/grub
You can add nomodeset to
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
so that it becomes
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nomodeset"
Save the file and after that run the command
sudo update-grub
to get the boot option nomodeset active the next time you boot.
If you have nvidia graphics, it might be worth trying with a proprietary graphics driver to use the whole power of the chip/card, and this will only work in an installed system.
sudodus
  • 47,684
