Recently I set a password containing small c cedilla (รง) and now I can't type it on login menu because it doesn't use the Spanish but English keyboard and types a slash, resulting in wrong password. How could I login?
You will need to reset you password. First restart your PC, wait for the GRUB menu to appear(similar to this)grub menu
Now, select the Advanced option for Ubuntu and click Enter There will be two options, select the option to go to recovery mode.
Now you will be present with different options of recovery mode. Now you have to choose Root Drop into root shell prompt
You need to have write access to the root partition. By default, it has only read-only access using the command
mount -rw -o remount /
Now, list all the users that are present in the system
ls /home
Use the command
passwd username
where username is the user from the list whose password is to be reset. passwd is used to set a password
It will prompts for a new password. Enter the new password twice (there will be no visual feedback i.e: you wont see any characters on the screen)
Then exit the root shell prompt by typing exit
When you exit, you will be back to the recovery mode menu. Select resume for normal boot option.
