Twiki is running locally on my web server apache2. I used a2enmod ssl to enable SSL (Secure Socket Layer). Now i want to see SSL is enabled or not ? Or i need more configurations to achieve task (i-e) to enable SSL.
Asked
Active
Viewed 9,667 times
DK Bose
- 44,553
Haider Yaqoob
- 255
In case you haven't already done so, do a:
service apache2 restart
after the a2enmod ssl you just did.
Then, you use the following command to test SSL:
curl -vk https://localhost/ -o /dev/null
Fabby
- 35,017
Алексей Востриков
- 121
- 9
