I tried installing Cuda 10.1 according to the instructions on the site. After that, I made a simple C program to test out nvcc, and it said I didn't have some nvidia-cuda package installed.
I installed it with apt-get, and the download completed with one error, that nvidia-cuda-dev couldn't be installed.
Now I can't open nvidia-settings, because nvidia-cuda-dev has an unmet dependency, and I can't remove all nvidia pakcages with apt purge, because nvidia-cuda-dev has an unmet dependency.
Not sure what to do next, I'll be here a while.
P.S : I've also tried using
sudo apt --fix-broken install
but it says nvidia-cuda-dev is going to be installed, but then says :
dpkg: error processing archive /var/cache/apt/archives/nvidia-cuda-dev_9.1.85-3ubuntu1_amd64.deb (--unpack): trying to overwrite '/usr/include/cublas.h' which is also in package libcublas-dev 10.2.1.243-1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Errors were encountered while processing: /var/cache/apt/archives/nvidia-cuda-dev_9.1.85-3ubuntu1_amd64.deb
damadam
  • 2,873
I found what was going on: I had turned my nvidia-settings to use only intel card, I had to go into root to toggle that, and then restart. Then the packages could be uninstalled. I'll post the forum that I read this from.
your package system is broken.
first aid.
sudo mv /usr/include/cublas.h $HOME
moves file in user home. 2 packages containing the same file.
sudo dpkg --configure -a && sudo apt -f install
After that, one of the package has to be removed. libcublas-dev 10.2.1.243-1 or nvidia-cuda-dev_9.1.85-3ubuntu1.
nobody
  • 5,792
