I installed Ubuntu 18.04 on a separate external drive along with my Windows 10. The Ubuntu installation is successful but I can no longer boot Windows 10, not even from the BIOS using boot override. The files seem to be intact since I can mount the drive and look through the files. It also doesn't show up in the GRUB menu.
I have tried the solutions given by GRUB does not detect Windows but the os-prober doesn't find my Windows installation. lsblk shows the partitions but there is no /boot/efi as shown in the following result.
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 14,8M 1 loop /snap/gnome-characters/296
loop1 7:1 0 3,7M 1 loop /snap/gnome-system-monitor/100
loop2 7:2 0 65,9M 1 loop /snap/discord/101
loop3 7:3 0 42,8M 1 loop /snap/gtk-common-themes/1313
loop4 7:4 0 181,1M 1 loop /snap/spotify/36
loop5 7:5 0 136,9M 1 loop /snap/code/20
loop6 7:6 0 4M 1 loop /snap/gnome-calculator/406
loop7 7:7 0 1008K 1 loop /snap/gnome-logs/61
loop8 7:8 0 149,9M 1 loop /snap/gnome-3-28-1804/67
loop9 7:9 0 88,5M 1 loop /snap/core/7270
loop10 7:10 0 54,4M 1 loop /snap/core18/1066
sda 8:0 0 931,5G 0 disk
├─sda1 8:1 0 128M 0 part
└─sda2 8:2 0 931,4G 0 part
sdb 8:16 0 232,9G 0 disk
├─sdb1 8:17 0 450M 0 part
├─sdb2 8:18 0 99M 0 part
├─sdb3 8:19 0 16M 0 part
├─sdb4 8:20 0 231,8G 0 part
└─sdb5 8:21 0 517M 0 part
sdc 8:32 0 931,5G 0 disk
└─sdc1 8:33 0 931,5G 0 part /
Why am I unable to boot my Windows 10?
EDIT: As suggested by Paul Benson here are the outputs for grep -i -A10 windows /boot/grub/grub.cfg:
$ grep -i -A10 windows /boot/grub/grub.cfg
menuentry "Windows 10" {
set root='{hd0,1}'
chainloader + 1
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
And sudo fdisk -l|grep -A4 /dev/sd:
Partition 1 does not start on physical sector boundary.
Disk /dev/sda: 931,5 GiB, 1000204886016 bytes, 1953525168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
/dev/sda1 34 262177 262144 128M Microsoft reserved
/dev/sda2 264192 1953523711 1953259520 931,4G Microsoft basic data
Disk /dev/sdb: 232,9 GiB, 250059350016 bytes, 488397168 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
/dev/sdb1 2048 923647 921600 450M Windows recovery environment
/dev/sdb2 923648 1126399 202752 99M EFI System
/dev/sdb3 1126400 1159167 32768 16M Microsoft reserved
/dev/sdb4 1159168 487335654 486176487 231,8G Microsoft basic data
/dev/sdb5 487335936 488394751 1058816 517M Windows recovery environment
Disk /dev/sdc: 931,5 GiB, 1000170586112 bytes, 1953458176 sectors
Disklabel type: dos
/dev/sdc1 * 2048 1953456127 1953454080 931,5G 83 Linux
Disk /dev/loop8: 149,9 MiB, 157184000 bytes, 307000 sectors
