I'm booting Ubuntu 16.04 from a USB Stick on my MacBook Pro 2018. When I chose either Try Ubuntu without installing or Install Ubuntu, I get the following error code and the Kernel panics:
ACPI Exception: AE_NO_MEMORY, SSDT 0xFFFF9E606B75CC00 Table is duplicated (20170831/tbdata-562)
ACPI Error: Method parse/execution failed \_PR.CPU0.GCAP, AE_ALREADY_EXISTS (20170831/psparse-550)
ACPI Error: Method parse/execution failed \_PR.CPU0._PDC, AE_ALREADY_EXISTS (20170831/psparse-550)
ACPI Exception: AE_NO_MEMORY, SSDT 0xFFFF9E606BBDF800 Table is duplicated (20170831/tbdata-562)
ACPI Error: Method parse/execution failed \_PR.CPU1.APPT, AE_ALREADY_EXISTS (20170831/psparse-550)
ACPI Error: Method parse/execution failed \_PR.CPU1.GCAP, AE_ALREADY_EXISTS (20170831/psparse-550)
ACPI Error: Method parse/execution failed \_PR.CPU1._PDC, AE_ALREADY_EXISTS (20170831/psparse-550)
ACPI Exception: AE_NO_MEMORY, SSDT 0xFFFF9E606B57A400 Table is duplicated (20170831/tbdata-562)
ACPI Error: Method parse/execution failed \_PR.CPU1.APCT, AE_ALREADY_EXISTS (20170831/psparse-550)
ERROR: Unable to locate IOAPIC for GSI 34
BUG: stack guard page was hit at (ptrual (stack is (ptural).. (ptural))
kernel stack overflow (page fault): 0000 [#1] SMP PT1
Modules linked in:
Kernel panic - not syncing: Attepted to kill init! exit code=0x0000000b
Kernel Offset: 0x29e00000 from 0xffffffff81000000 (relocation range: 0xfffffffff80000000-0xfffffffffbfffffff)
-- [ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
where the ... contains some more info that I believe is not helpful.
Does anyone have an idea how to fix that?
I have already tried setting acpi=off as suggested at ACPI Errors when booting , Can't boot
When I did, I just got a black screen for hours.
Edit: the same stick on a different non-mac laptop works.
