I am running ubuntu 18.04 and I currently have:
(tensorflow_p36) ubuntu@user:~$ gcc --version
gcc (GCC) 4.8.5
(tensorflow_p36) ubuntu@user:~$ gcc-8 --version
gcc-8 (Ubuntu 8.3.0-6ubuntu1~18.04.1) 8.3.0
(tensorflow_p36) ubuntu@user:~$ which gcc
/home/ubuntu/anaconda3/envs/tensorflow_p36/bin/gcc
I am trying to use the latest gcc-8 as show here. However when I run
sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-8 800 --slave /usr/bin/g++ g++ /usr/bin/g++-8
I get the following error:
update-alternatives: error: alternative g++ can't be slave of gcc: it is a master alternative
When I try:
(tensorflow_p36) ubuntu@user:~$ sudo update-alternatives --config gcc
I get another error:
update-alternatives: error: no alternatives for gcc
How is it that I do not have alternative for gcc? Any suggestions on how I can resolve this error and configure gcc-8 to be the default gcc installation would be appreciated.
Running which gcc from outside the conda environment does not return anything:
ubuntu@user:~$
but
I tried following the question here:
(tensorflow_p36) ubuntu@user:~$ sudo apt install g++-8
g++-8 is already the newest version (8.3.0-6ubuntu1~18.04.1).
and
(tensorflow_p36) ubuntu@user:~$ sudo apt install gcc-8
gcc-8 is already the newest version (8.3.0-6ubuntu1~18.04.1).
Update. I'm trying the following as per the helpful suggestion below, but still to no avail.
(tensorflow_p36) ubuntu@user:~$ sudo update-alternatives --install /usr/bin/g++ g++ /usr/bin/g++-8 40
(tensorflow_p36) ubuntu@user:~$ sudo update-alternatives --install /usr/bin/g++ g++ /usr/bin/g++-4.8 60
(tensorflow_p36) ubuntu@user:~$ sudo update-alternatives --config g++
There are 3 choices for the alternative g++ (providing /usr/bin/g++).
  Selection    Path                             Priority   Status
* 0            /usr/bin/x86_64-linux-gnu-g++-7   100       auto mode
  1            /usr/bin/g++-4.8                  60        manual mode
  2            /usr/bin/g++-8                    40        manual mode
  3            /usr/bin/x86_64-linux-gnu-g++-7   100       manual mode
Press <enter> to keep the current choice[*], or type selection number: 2
update-alternatives: using /usr/bin/g++-8 to provide /usr/bin/g++ (g++) in manual mode
So far so good, but when I test the g++ version, it's still the same!
~$ g++ --version
g++ (GCC) 4.8.5
EDIT
I also try with gcc:
There are 2 choices for the alternative gcc (providing /usr/bin/gcc).
  0            /usr/bin/gcc-8     80        auto mode
  1            /usr/bin/gcc-4.8   60        manual mode
* 2            /usr/bin/gcc-8     80        manual mode
Press <enter> to keep the current choice[*], or type selection number: 0
gcc (GCC) 4.8.5
rrz0
  • 181
