I'm having some permissions issues with Ubuntu 19.10. I have 3 disks:
sda/
sda1/ntfs with win10
sda2/efi
sda3/ext4 ubuntu 19.10
sdb/ntfs with files
sdc/ntfs with files
I've installed qbitorrent and cannot write to sdb but it can to sdc. I've installed emby also which cannot write neither sdb nor sdc.
I've been playing around with fstab trying different options but none of them worked.
I've also performed sudo chown -R user:user /mount point but same result
This is my fstab, i've tried different dmask and fmask values, also ntfs instead of ntfs-3g
UUID=C828D8A328D891B4 /home/user/series ntfs-3g auto,defaults,rw,users,uid=1000,gid=1000,utf8,dmask=002,fmask=113 0 0
UUID=38EC7FB0EC7F6752 /home/user/stuff ntfs-3g auto,defaults,rw,users,uid=1000,gid=1000,utf8,dmask=002,fmask=113 0 0
This is the result of sudo fdisk -l
Disk /dev/sda: 111,81 GiB, 120034123776 bytes, 234441648 sectors
Disk model: KINGSTON SV300S3
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xb6e9d141
Device Boot Start End Sectors Size Id Type
/dev/sda1 2048 718847 716800 350M 7 HPFS/NTFS/exFAT
/dev/sda2 718848 192509951 191791104 91,5G 7 HPFS/NTFS/exFAT
/dev/sda3 233476096 234434559 958464 468M 27 Hidden NTFS WinRE
/dev/sda4 192511998 233476095 40964098 19,5G 5 Extended
/dev/sda5 192903168 233476095 40572928 19,4G 83 Linux
/dev/sda6 * 192512000 192903167 391168 191M ef EFI (FAT-12/16/32)
Partition table entries are not in disk order.
Disk /dev/sdc: 3,65 TiB, 4000787030016 bytes, 7814037168 sectors
Disk model: WDC WD40EZRZ-00W
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 4789F54E-36DD-4A49-B872-C95CC42433A1
Device Start End Sectors Size Type
/dev/sdc1 34 262177 262144 128M Microsoft reserved
/dev/sdc2 264192 7814035455 7813771264 3,7T Microsoft basic data
Partition 1 does not start on physical sector boundary.
Disk /dev/sdb: 1,84 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: ST2000DL003-9VT1
Disklabel type: dos
Disk identifier: 0xd85e2c94
/dev/sdb1 63 3907027119 3907027057 1,8T 42 SFS
I can copy/move files with nautilus easily to every disk.
I'm kind of lost, I don't know what else I can try.
Thanks in advance
