I just really want to delete all of cuda and cudnn packages, but I cant use the apt-get at all because it always come with this mistake. Ive tried to much different things. Ive even located the broken package in synaptic, which is the nvidia-cuda-toolkit 9.1.85-3ubuntu1. I know maybes its a kind of silly problem, but im stuck at it. Help : ).
(base) itamar@itamar-PC:~$ sudo apt-get install nvidia-cuda-dev
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
libatomic1:i386 libbsd0:i386 libdrm-amdgpu1:i386 libdrm-intel1:i386
libdrm-nouveau2:i386 libdrm-radeon1:i386 libdrm2:i386 libedit2:i386
libelf1:i386 libexpat1:i386 libffi6:i386 libgl1:i386 libgl1-mesa-dri:i386
libglapi-mesa:i386 libglvnd0:i386 libglx-mesa0:i386 libglx0:i386
libllvm8:i386 libnvidia-common-430 libpciaccess0:i386 libsensors4:i386
libstdc++6:i386 libx11-6:i386 libx11-xcb1:i386 libxau6:i386
libxcb-dri2-0:i386 libxcb-dri3-0:i386 libxcb-glx0:i386 libxcb-present0:i386
libxcb-sync1:i386 libxcb1:i386 libxdamage1:i386 libxdmcp6:i386 libxext6:i386
libxfixes3:i386 libxshmfence1:i386 libxxf86vm1:i386
Use 'sudo apt autoremove' to remove them.
Recommended packages:
libvdpau-dev libnvcuvid1
The following NEW packages will be installed:
nvidia-cuda-dev
0 upgraded, 1 newly installed, 0 to remove and 2 not upgraded.
1 not fully installed or removed.
Need to get 0 B/263 MB of archives.
After this operation, 734 MB of additional disk space will be used.
Selecting previously unselected package nvidia-cuda-dev.
(Reading database ... 280498 files and directories currently installed.)
Preparing to unpack .../nvidia-cuda-dev_9.1.85-3ubuntu1_amd64.deb ...
Unpacking nvidia-cuda-dev (9.1.85-3ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/nvidia-cuda-dev_9.1.85-3ubuntu1_amd64.deb (--unpack):
trying to overwrite '/usr/include/cublas.h', which is also in package libcublas-dev 10.2.2.89-1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
(base) itamar@itamar-PC:~$ sudo apt autoremove
You might want to run 'apt --fix-broken install' to correct these.
nvidia-cuda-toolkit : Depends: nvidia-cuda-dev (= 9.1.85-3ubuntu1) but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
