This problem is a bit weird. Three days ago I tried to boot, and it got stuck on the loading screen. After some research I found out it was because my root partition was completely full.
After some more research I found out that what's filled it was the kern.log and syslog files (which together took about 16G), that both had the following loop:
Nov 22 12:02:39 kazimir-ubuntu-18-04 kernel: [ 645.191850] pcieport 0000:00:1c.5: device [8086:9d15] error status/mask=00000001/00002000
Nov 22 12:02:39 kazimir-ubuntu-18-04 kernel: [ 645.191852] pcieport 0000:00:1c.5: [ 0] RxErr
Nov 22 12:02:39 kazimir-ubuntu-18-04 kernel: [ 645.191875] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
Nov 22 12:02:39 kazimir-ubuntu-18-04 kernel: [ 645.191880] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
After some more headaches, I listed my wireless adapter to be unmanaged by adding the following line in /etc/NetworkManager/NetworkManager.conf:
unmanaged-devices=mac:54:...
I am using a wired internet connection, but obviously that's not ideal. So the most logical thing to me was to update the drivers.
My adapter is a Realtek RTL8723BE PCIe Wireless Network Adapter, so I did as was suggested in this answer by Tobias Lekare.
The update seemed to work fine, I commented the line I added in NetworkManager.conf and reboot-ed. But sadly the problem persists. The logs keep blowing up with the same lines. I know the problem is the wireless adapter but I'm truly lost as to why this happens.
I am using a dual-boot with Windows 10 if relevant, but everything worked completely fine for months.
These are the details of the wireless connection adapter:
*-network DISABLED
description: Wireless interface
product: RTL8723BE PCIe Wireless Network Adapter
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlp3s0
version: 00
serial: 54:..
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=rtl8723be driverversion=5.0.0-36-generic firmware=N/A latency=0 link=no multicast=yes wireless=IEEE 802.11
resources: irq:17 ioport:c000(size=256) memory:df100000-df103fff
