I am attempting to replace tokens in a JSON file with values held in our CI tool of choice (Bamboo).
To do this, I am using jq to extract an array of values, and then replacing the token in each value with its corresponding Bamboo variable value.
However, something is not working. The output on the scrip confirms that the replacement token is being found, and that the Bamboo variable value is correct.
What am I doing wrong?
ENV_FILE_PATH="./landmark-accounts-uat.postman_environment.json"
VALUES=$(cat ./landmark-accounts-uat.postman_environment.json | jq -c '.values[]')
for ELEMENT in $VALUES; do
### Extract the variable name and replacement token (e.g. '#{varName}') for the current element.
ELEMENT_NAME=$(echo $ELEMENT | jq -r '.key')
ELEMENT_REPLACEMENT_TOKEN=$(echo $ELEMENT | jq -r '.value')
### Construct the name of the Bamboo variable to use for replacement.
BAMBOO_VARIABLE_NAME=bamboo\_$ELEMENT_NAME
BAMBOO_VARIABLE_VALUE=${!BAMBOO_VARIABLE_NAME}
### Replace the current value with the value of the Bamboo variable.
echo "Replacing '$ELEMENT_REPLACEMENT_TOKEN' with the value of Bamboo variable '$BAMBOO_VARIABLE_NAME' ($BAMBOO_VARIABLE_VALUE)."
sed -i 's/$ELEMENT_REPLACEMENT_TOKEN/$BAMBOO_VARIABLE_VALUE/g' $ENV_FILE_PATH
done
Example JSON file
Below is an example of the JSON file before it's been edited with sed.
As you can see, there are replacement tokens for each value, and it is these that I am trying to replace with Bamboo variables. In this case, those varaibles would be called $bamboo_apiUrl and $bamboo_apimKey.
"id": "b10a67a9-75a1-49fc-8b6d-9063388ed35c",
"name": "my-env",
"values": [
"key": "apiUrl",
"value": "#{apiUrl}",
"enabled": true
"key": "apimKey",
"value": "#{apimKey}",
"enabled": true
"_postman_variable_scope": "environment",
"_postman_exported_at": "2019-09-27T09:13:43.208Z",
"_postman_exported_using": "Postman/7.8.0"
Update
Based on a suggestion in the comments, this is the solution that I am using.
#!/bin/bash
### Read in the environment file in full.
ENVIRONMENT_FILE=$(cat $ENV_FILE_PATH)
### Get all of the value keys from the environment file.
KEYS=$(cat $ENV_FILE_PATH | jq --raw-output '.values[].key')
### Iterate value keys...
for KEY in $KEYS; do
### Construct the name of the Bamboo variable to use for 'value' for the current 'key', then get the value of that variable.
BAMBOO_VARIABLE_NAME=bamboo\_$KEY
### Replace the value for the currently 'key'.
echo "Replacing value of key '$KEY' with the value of Bamboo variable '$BAMBOO_VARIABLE_NAME' ($BAMBOO_VARIABLE_VALUE)."
ENVIRONMENT_FILE=$(echo $ENVIRONMENT_FILE | jq --arg key "$KEY" --arg value "$BAMBOO_VARIABLE_VALUE" '.values |= map(if .key == $key then .value = $value else . end)')
done
### Output the updated environment file.
echo $ENVIRONMENT_FILE > $ENV_FILE_PATH
