I'm new to nmcli and trying to figure out how to create an eth0 connection. sudo nmcli con prints the following:
NAME UUID TYPE DEVICE
MyWlan0 ... wifi wlan0
MyEth0 ... ethernet --
No matter what command I give, my MyEth0 connection will not show eth0 under DEVICE above (just '--') and, as a result, I'll get the following error when I try sudo nmcli con up MyEth0:
Error: Connection activation failed: No suitable device found for this connection (device lo not available because device is strictly unmanaged).
This is how I created the connection:
sudo nmcli con add con-name MyEth0 type ethernet ifname eth0
I've also tried modifying it with the following sorts of commands:
sudo nmcli con mod MyEth0 connection.interface-name eth0
Running sudo nmcli con show MyEth0 connection | grep eth0 does indicate that the connection.interface-name is eth0, but it does not appear this way according to the behavior described above.
Any ideas?
Edit:
Here is the output of sudo lshw -C network:
*-network:0
description: Ethernet interface
physical id: 2
logical name: eth0
serial: dc:a6:32:27:84:45
capacity: 1Gbit/s
capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=bcmgenet driverversion=v2.0 duplex=full link=yes multicast=yes port=MII speed=100Mbit/s
*-network:1
description: Wireless interface
physical id: 3
logical name: wlan0
serial: dc:a6:32:27:84:46
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=brcmfmac driverversion=7.45.18 firmware=01-6a2c8ad4 ip=192.168.1.201 multicast=yes wireless=IEEE 802.11
