hope I'm in the right place.
I'm following this instruction : https://tecadmin.net/install-zabbix-on-ubuntu/
Instead of installing the zabbix-release_4.2-1+bionic_all.deb, I downloaded the zabbix-release_4.4-1+bionic_all.deb file.
By the installation of the zabbix-server-mysql and zabbix-frontend-php and zabbix-agent, the following error-output shows up:
ahmedsmaha@DarkStar:~$ sudo apt install zabbix-server-mysql zabbix-frontend-php zabbix-agent
Reading package lists... Done
Building dependency tree
zabbix-server-mysql : Depends: libmysqlclient20 (>= 5.7.11) but it is not installable
Recommends: snmpd but it is not going to be installed
