I'm new to both Linux and this website so feel free to point out if I gave to little information.
I have a common problem of not working wifi adapter although wired works fine. I installed driver for rtl8168 which I assume is correct one because after installation my download speed increased up to the level of my second PC which has Windows installed. However, wifi still isn't working. The Realtek website states that driver is working with the kernels up to 4.15 and I'm wonder should I try installing some of the older kernels. I'm asking because once I've already broken everything to the point when both wired and wireless connections weren't working.
For clarity, here is the result of network check with lshw -c network.
*-network
   description: Ethernet interface
   product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
   vendor: Realtek Semiconductor Co., Ltd.
   physical id: 0
   bus info: pci@0000:02:00.0
   logical name: eno1
   version: 15
   serial: 10:62:e5:81:df:39
   capacity: 1Gbit/s
   width: 64 bits
   clock: 33MHz
   capabilities: bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
   configuration: autonegotiation=on broadcast=yes driver=r8168 driverversion=8.047.05-NAPI duplex=full ip=78.85.166.250 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
   resources: irq:50 ioport:3000(size=256) memory:e0804000-e0804fff memory:e0800000-e0803fff
 *-network UNCLAIMED
   description: Network controller
   product: Realtek Semiconductor Co., Ltd.
   physical id: 0
   bus info: pci@0000:03:00.0
   version: 00
   width: 64 bits
   clock: 33MHz
   capabilities: cap_list
   configuration: latency=0
   resources: ioport:2000(size=256) memory:e0700000-e070ffff
Edit1: wifi controller is internal.
Edit2 (result of lspci -nnk | grep -iA3 net):
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15) Subsystem: Hewlett-Packard Company RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [103c:84ae] Kernel driver in use: r8168 Kernel modules: r8168 03:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. Device [10ec:d723] Subsystem: Hewlett-Packard Company Device [103c:8319] 04:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] [1002:15dd] (rev c4) Subsystem: Hewlett-Packard Company Vega [Radeon Vega 8 Mobile] [103c:84ae]
trofchik
