According to https://www.amd.com/en/support/kb/faq/gpu-635.
First, you should update your system with sudo apt update; sudo apt dist-upgrade; sudo reboot. After reboot, you should check if AMDGPU-PRO Driver package is already installed on your system with dpkg -l amdgpu-pro. Then, download your specific amd driver with wget --referer=https://www.amd.com https://drivers.amd.com/drivers/linux/amdgpu-pro-19.30-934563-ubuntu-18.04.tar.xz, extract its contents with tar -Jxvf amdgpu-pro-19.30-934563-ubuntu-18.04.tar.xz and enter in the driver directory with cd amdgpu-pro-19.30-934563-ubuntu-18.04. Finally, you could install it with ./amdgpu-pro-install -y; sudo reboot
Make sure you are a member of the video group with groups command and, if you are not yet in that group, just add yourself with sudo usermod -a -G video $LOGNAME.
If anything goes wrong, you can remove AMDGPU-PRO driver with amdgpu-pro-uninstall.
That's it.
If this answer don't work, consider reformulating your question with the exact steps that you made before getting to your current point.
Here is a overview of all commands typed above for preparing your distro, downloading your specific driver and installing it.
dpkg -l amdgpu-pro
