I'm trying to perform --auto-tune in powertop, however I get the following error
Cannot load from file /var/cache/powertop/saved_parameters.powertop
If I browse to that directory the file does exist.
I started by running --calibrate first, which completed okay.
Here is the full print out;
~ $ sudo powertop --auto-tune
modprobe cpufreq_stats failedLoaded 48 prior measurements
File will be loaded after taking minimum number of measurement(s) with battery only
RAPL device for cpu 0
RAPL Using PowerCap Sysfs : Domain Mask f
Devfreq not enabled
glob returned GLOB_ABORTED
To show power estimates do 333 measurement(s) connected to battery only
Leaving PowerTOP
Kaigo
  • 585
That is normal. You see the explanation File will be loaded after taking minimum number of measurement(s) with battery only.
This warning will go away after some time.
Pilot6
  • 92,041
Run sudo powertop for some time and the counter will reach 0
