sudo apt-get install python 3.5.8
Reading package lists... Done
Building dependency tree
Note, selecting 'libghc-blaze-svg-dev-0.3.5-84036:i386' for regex '3.5.8'
Note, selecting 'libghc-blaze-svg-prof-0.3.5-84036:i386' for regex '3.5.8'
Note, selecting 'libghc-blaze-svg-dev:i386' instead of 'libghc-blaze-svg-dev-0.3.5-84036:i386'
Note, selecting 'libghc-blaze-svg-prof:i386' instead of 'libghc-blaze-svg-prof-0.3.5-84036:i386'
dkms : Breaks: shim-signed (< 1.33.1~16.04.4) but 1.12+0.8-0ubuntu2 is to be installed
libghc-blaze-svg-dev:i386 : Depends: libghc-base-dev-4.8.2.0-a3ce8:i386
Depends: libghc-blaze-markup-dev-0.7.0.3-608bf:i386
Depends: libghc-mtl-dev-2.2.1-05005:i386
libghc-blaze-svg-prof:i386 : Depends: libghc-base-prof-4.8.2.0-a3ce8:i386
Depends: libghc-blaze-markup-prof-0.7.0.3-608bf:i386
Depends: libghc-mtl-prof-2.2.1-05005:i386
Asked
Active
Viewed 2,585 times
newbiecoder
- 11
- 2
- 5
Python 3.5 is installed on Ubuntu 16.04 by default.
Please check python3.5 --version in a terminal.
Jürgen Gmach
- 720
You do not provide the version number just as argument. This causes apt-get install to look for packages matching "3.5.8". If you want a specific package version check out https://askubuntu.com/a/428778/756449
malliaridis
- 131
