I want to see my all packages and modules of node-module. Please tell me its the location in ubuntu 18.04. such as /path/to/node-module. Moreover, How to see the code of modules such as http module or fs module.
Global libraries
You can run npm list -g to see which global libraries are installed and where they're located. Use npm list -g | head -1 for truncated output showing just the path.
On Unix systems they are normally placed in /usr/local/lib/node or /usr/local/lib/node_modules when installed globally. If you set the NODE_PATH environment variable to this path, the modules can be found by node.
Non-global libraries
Non-global libraries are installed the node_modules sub folder in the folder you are currently in. You can run npm list to see the installed non-global libraries for your current location.
You can see the local location like this:
$ npm root
/home/<user>/<path>/node_modules
and the global location like this:
$ npm root -g
/usr/lib/node_modules
node_modules installed globally are rooted in the library where sudo admin is necessary to access
marcdahan
  • 121
