I mostly keep my bluetooth off on my laptop. Whenever I reboot my laptop it also is on. Im running Ubuntu 18.04.3 LTS on a Lenovo E41-15 with stock hardware and an extra 120gb SSD as boot drive.
18.04+ users who don't naturally have a /etc/rc.local, you'll need to create one and make it executable. To make things slightly easier, you can just paste the following command into a terminal:
sudo install -b -m 755 /dev/stdin /etc/rc.local << EOF
#!/bin/sh
rfkill block bluetooth
exit 0
EOF
Run sudoedit /etc/rc.local and add this before line with exit 0:
You should still be able to enable Bluetooth through the top bar applet.
This should work for most systems but it looks like there are a few bugs lurking in the kernel's ACPI for Thinkpads. If you're on a Thinkpad, add the following to /etc/rc.local:
echo disable > /proc/acpi/ibm/bluetooth
[Source]
