I am using a dev tool for working with mongodb. It was working fine yesterday. when I came today I get this error while running the appImage in terminal
fusermount: mount failed: Operation not permitted
Cannot mount AppImage, please check your FUSE setup. You might still be able to extract the contents of this AppImage if you run it with the --appimage-extract option. See https://github.com/AppImage/AppImageKit/wiki/FUSE for more information open dir error: No such file or directory
I normally call it using terminal by going over to my downloads directory then hitting the command
./nosqlbooster4mongo*.AppImage
I looked over the internet but couldn't find a satisfactory solution. I am extremely new to ubuntu, so maybe I did something wrong?
user3692459
  • 411
After hours of searching found the solution!
This happens with fuse. Instead of this
I added an extra clause of
--appimage-extract-and-run
Now you can run your appImage like
./nosqlbooster4mongo*.AppImage --appimage-extract-and-run
Hope this helps anyone else who faces this issue!
Gryu
  • 8,002
  • 37
  • 53
user3692459
  • 411
