49
Some minutes ago my computer crashed because apparently my hard drive was full. After booting in recovery mode I then found out that my syslog file in /var/log was 64GB large. I saved the end of the file on another partition and then deleted it. Apparently docker seems to have been the problem because I found a lot of this at the end of the file and there was a docker process running at 200% CPU the whole time. After clearing the log and killing docker everything seems to be normal.
Nov 15 01:44:08 Elemental docker.dockerd[1120]:
time="2019-11-15T01:44:08.727060251Z" level=error
msg="failed to get event" error="rpc error: code =
Unavailable desc = all SubConns are in TransientFailure, latest connection
error: connection error: desc = \"transport: Error
while dialing dial unix /run/containerd/containerd.sock:
connect: permission denied\"" module=libcontainerd namespace=plugins.moby
Nov 15 01:44:08 Elemental docker.dockerd[1120]:     time="2019-11-15T01:44:08.727116701Z"
And so on. I hope this problem won't appear again but still I would like to know what might have happened here.
Philip Z.
  • 880
7 Answers7
48
I had docker package installed through apt and snap at the same time. So the issue is fixed by removing docker through the snap packaging system.
# apt list --installed | grep docker
docker/bionic,now 1.5-1build1 amd64 [installed]
docker-ce/bionic,now 5:19.03.5~3-0~ubuntu-bionic amd64 [installed]
docker-ce-cli/bionic,now 5:19.03.5~3-0~ubuntu-bionic amd64 [installed,automatic]
# snap list | grep docker
docker                18.09.9                     418   stable    canonical✓  -
# snap remove docker
docker removed
Adivinho
  • 526
Someone at Cannonical screw things up few hours ago - it's tracked on launchpad - https://bugs.launchpad.net/ubuntu/+source/snapd/+bug/1852720
My system was installed yesterday with docker only and same as rest of folks here - syslog killed entire free space on disk, purging docker from snap helped.
dskowronski
  • 161
You have multiple docker services running. Looks like dockerd is trying to access the different installation of containerd, spamming syslog.
In my case, the teamcity agent and docker installation was conflicted.
sudo apt-get purge docker-ce
sudo apt autoremove
sudo rm -rf /var/lib/docker
sudo truncate -s 0 /var/log/syslog
Ran those commands above and restarted. everything went okay.
Chris Sung
  • 91
Happened to me too. I wonder if it was a snap updated that made it happen:
ID   Status  Spawn               Ready               Summary
17   Done    today at 00:34 UTC  today at 00:34 UTC  Auto-refresh snap "docker"
Uninstall+reinstall of Ubuntu's docker.io package brings back this problem, but for some reason I also had a snap of docker installed, so that's what triggered the conflict.
Name    Version    Rev   Tracking  Publisher   Notes
core    16-2.42.1  8039  stable    canonical✓  core
However, I don't remember that I ever installed the docker snap package... but this is a test-system after all, someone else might have thought that it was a good idea...
frpet
  • 61
I ran into this problem too, so just in case other people wander in here I can describe the solution that worked for me. I first tried Chris Sung's suggestion but that did not work.
The symptoms were:
  1. dockerb running at 200+% CPU, and would constantly restart with a kill command
  2. Giant files being filled in syslog as Philip Z. saw. When I came in this morning it had filled up my entire hard drive with a 700GB file.
Frist remove the huge file so you can actually do stuff. It will start filling up again, but you should have some time.
Then remove the snap docker installation. This was the problem for me, not docker-ce
sudo snap stop docker
sudo snap remove docker
I'm not sure it's necessary, but I went ahead and got rid of snap altogether too
sudo apt purge snap
You should no longer see dockerb in top. You can then rerun the log truncator to remove any junk that was written while you were doing the above commands. If you screw up as I did and delete the syslog altogether, make sure that you give the new syslog the correct permissions.
sudo cd /var/log
sudo touch syslog
sudo chown syslog:adm syslog
sudo service rsyslog restart
Zanna
  • 72,312
Same problem here too since this night.
Docker containers (mosquitto/influxdb/grafana) are not accessible on their respective ports.
Unable to stop containers, until using --force.
Forced stop all containers but message on restarting each one is always the same :
"docker: Error response from daemon: all SubConns are in TransientFailure"
I did Silvio's package removal. Then, to restart docker daemon, I ran these commands as root:
systemctl unmask docker.service
systemctl unmask docker.socket
systemctl start docker.service
service docker start
Seems to be good now. Thanks to @Silvio.
Eliah Kagan
  • 119,640
I got low space warning on ubuntu.
The space is not enough for me to analyze which repeated log mess up/var/log
But the most recent logs are exact same as you.
I tried check which process write most to disk, but found docker's cpu % is over 250.
snap changes | grep docker
it seems docker snap installed by itself
54 Done yesterday at 23:31 EST yesterday at 23:31 EST Auto-refresh snap "docker
sudo snap remove docker --purge
should remove the docker snap and immediately release some space
ychz
  • 131
