Just a bit of backstory, I am at a work-search office today on one of their computers and it has no permissions whatsoever, making their computers nigh impossible to use for me, particularly because I use a highly customed keyboard layout only available in Linux.
I have my thumb-drive today however, and thought I would make a bootable-usb that I can work from instead. The thing is, is that without any permissions, I can not run any of the USB thumb drive installers, and so I am trying to figure out how to do this manually. I already have the thumb drive formatted to Fat, so is it just a matter of copying the ISO contents to the drive? Thanks.
Anon
  • 12,339
To Confirm Ability to Create Live/Persistent USB in Windows 10 Without Administrator permissions
  • Format flash drive to as new state, (FAT32)
  • Open the 19.10 ISO in Windows 10 File Explorer and copy the contents to the flashdrive.
Persistence
There are several methods to make the flash drive persistent. Using a casper-rw partition is not limited to 4GB.
Alt 1
  • Boot the drive using UEFI
  • At the grub menu press "e" to edit the menu
  • Add a space and "toram" after ..quiet splash,,,
  • Open GParted, select the USB drive, unmount and Resize/Move to make room for a persistent partition
  • In the available space create an ext4 partition and label it casper-rw
  • Mount grub.cfg. In Terminal run
    sudo mkdir -p /mnt/sd1
    sudo mount /dev/sdx1 /mnt/sd1
Where x is the OS partition
  • As root edit boot/grub/grub.cfg by adding a space and the word persistent after the first ...quiet splash --- and save.
Alt 2
  • Open Boot/grub/grub.cfg in Windows 10 latest build
  • After quiet splash ---, type a space and "persistent"
  • Change "persistent" to "toram"
The drive should now be ready for work
  • You can create a new user and install programs as you wish.
C.S.Cameron
  • 20,530
  • 78
  • 125
