I want to be able to install the latest stable R release for Ubuntu 18.04, I had the ubuntu version installed and so I removed it and then followed several guides like in this link.
No matter what I do I get the following output when I issue a sudo apt-get install r-base:
sudo apt install r-base
Reading package lists... Done
Building dependency tree
r-base : Depends: r-base-core (>= 3.6.1-3disco) but it is not going to be installed
Depends: r-recommended (= 3.6.1-3disco) but it is not going to be installed
Recommends: r-base-html but it is not going to be installed
What's wrong?
(I did all the apt update etc.)
