You can add new insults only by replacing existing insults of equal or greater length.
From the second answer in your link are these phrases:
ins_2001.h (2001 Space Odyssey insults):
* HAL insults (paraphrased) from 2001.
"Just what do you think you're doing Dave?",
"It can only be attributed to human error.",
Find the file
$ grepall "Just what do you think you're doing Dave?"
Binary file /usr/lib/sudo/sudoers.so matches
OK we now know the file name. That was the easy part.
Backup the file
First make a backup (because we always remember to do that right?):
$ sudo cp -a /usr/lib/sudo/sudoers{.so,.so.bak}
$ ll /usr/lib/sudo/sudoers{.so,.so.bak}
-rw-r--r-- 1 root root 316768 Oct 11 06:01 /usr/lib/sudo/sudoers.so
-rw-r--r-- 1 root root 316768 Oct 11 06:01 /usr/lib/sudo/sudoers.so.bak
Make the script
Then make our script called sudoinsults:
#!/bin/bash
# NAME: sudoinsult
# PATH: $HOME/askubuntu/
# DESC: For: https://askubuntu.com/questions/1188779/adding-new-sudo-insults
# DATE: November 14, 2019.
# NOTE: Change sudo insults to personal favorites
# Build array of insults from disk
IFS=$'\n' Arr=( $(cat sudoinsult.txt) )
# Initialize variables
File="/usr/lib/sudo/sudoers.so"
upper=0
Spaces=" "
Spaces="$Spaces"" "
[[ ${#Arr[@]} -gt 0 ]] && upper=$(( ${#Arr[@]} - 1 ))
[[ $upper -gt 0 ]] && for (( i=0; i<upper; i=i+2 )) ; do
Search="${Arr[i]}" # Move array indices to named variables
Replace="${Arr[i+1]}" # for a simpler life.
printf "Replacing: '%s'\n With: '%s'\n" "$Search" "$Replace"
if [[ "${#Search}" -lt "${#Replace}" ]] ; then
echo "Replacement can't be longer than original"
continue
elif [[ "${#Search}" -lt 8 ]] ; then
echo "Original insult cannot be less than 8 characters"
continue
elif [[ "${#Search}" -gt "${#Spaces}" ]] ; then
echo "Original insult cannot be longer than ${#Spaces} characters"
continue
elif [[ "${#Replace}" -lt 1 ]] ; then
echo "Replacement insult cannot be less than 1 character"
continue
elif ! grep "$Search" "$File" >/dev/null ; then
echo "Search insult not found in $File"
continue
fi
# Pad replacement with spaces as needed.
ReplaceS="$Replace${Spaces:0:$((${#Search} - ${#Replace}))}"
[[ "${#ReplaceS}" -ne "${#Search}" ]] && \
{ echo Internal error ReplaceS different length than Search; exit; }
# Looks wrong: https://unix.stackexchange.com/a/354493/200094
#y="${y:0:40}${forty:0:$((40 - ${#y}))}"
#echo "'${y}'"
sed -i "s/$Search/$ReplaceS/" "$File"
(( InsultCount++ ))
done
if [[ $upper -gt 0 ]] ; then
echo "$InsultCount Insults replaced."
else
echo "Insult file (sudoinsult.txt) does not exist or only has one line." >2
fi
Create the datafile
Hopefully no need to explain how to create a text file (hint: gedit)
$ cat sudoinsult.txt
Just what do you think you're doing Rick?
It can only be attributed to the beer.
Run the script and check results
$ sudo ./sudoinsult
Replacing: 'Just what do you think you're doing Dave?'
With: 'Just what do you think you're doing Rick?'
Replacing: 'It can only be attributed to human error.'
With: 'It can only be attributed to the beer.'
2 Insults replaced.
-rw-r--r-- 1 root root 316768 Nov 14 17:43 /usr/lib/sudo/sudoers.so
$ grep "Just what do you think you're doing Rick?" /usr/lib/sudo/sudoers.so
$ grep "It can only be attributed to the beer." /usr/lib/sudo/sudoers.so
